Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 04-29-2009, 08:45 PM
t747 t747 is offline
Wide turns
I just had the rack and pinion replaced and alignment done on my 1995 Maxima, now the car seems to making wide left turns.
For example, I would be pulling left into my parking space at my apartment or anywhere for that matter, and my car would turn very wide. Is the alignment bad?
It is very frustrating, I never had problems parking my car before I had this done.
Is it just the alignment that is off or something else?
Old 03-24-2011, 12:33 PM
William33 William33 is offline
Re: Wide turns
Well i am not that experienced with alignment numbers is very limited and if you turn the steering wheel in front your front toe will become numb for that you need to see the exact alignment numbers where as the tolerance are very wide here .
http://www.engineperformancechip.com]Nissan Performance Parts[/url]
Old 09-29-2011, 09:35 AM
mikethewarrior mikethewarrior is offline
Re: Wide turns
You have got this alignment done after changing the tires or with old ones only.
Mike Nissan Altima
Mods - Projector Headlights
Old 10-04-2011, 01:18 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Wide turns
Did you have the car aligned after you replaced the rack? If not, you need to.
