Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-29-2009, 08:32 PM
Lucarelli05 Lucarelli05 is offline
Exclamation 2003 Mustang 3.8 V6 Shifting Problems
When I shift from 2nd to 3rd and from 4th to 5th the gears grind and sometimes kick the shifter out of gear. Is this a syncronizer problem or something else? Can anyone shed a little light on the subject?
Old 04-30-2009, 01:52 AM
Davescort97 Davescort97 is offline
Escort guy
Re: 2003 Mustang 3.8 V6 Shifting Problems
Welcome to AF!
You are right. It is a syncronizer problem. Try double clutching to see if it shifts better. Not sure if you know what double clutching is. 1. You push in the clutch. 2. Put it into neutral. 3. Let out the clutch. 4. Push in the clutch again and shift into gear. Double clutching gets the gears turning at the same speed before you shift. If it doesn't grind double clutching I'm fairly certain your syncronizers are bad.
Old 04-30-2009, 09:57 PM
I never thought to try that. Thank you for the help. Would you have any idea how much it might cost for parts?
Old 05-01-2009, 01:26 PM
Escort guy
You will have to call the dealer for this. I suspect about $30 each. The parts won't be much, but the labor will be intensive.
