Old 04-29-2009, 06:56 PM
01GTP 01GTP is offline
Help
have a 01 grand prix and getting code po131have changed plugs and wires. the car will not idle, when i disconnected the mass car idled at 3k. changed the mass and car still will not idle help please car has 3.8 motor
Old 04-29-2009, 07:21 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Help
P0131 = O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
I would have a look at the Pre-cat 02 sensor thats mounted in your rear exhaust manifold. If it checks out, I myself would probably just replace the sensor. They do go bad from time to time and after years and milage tend to get "lazy" where the switching time becomes longer and longer. If you do replace it, you may need to rent or borrow an O2 sensor socket, and sometimes removing it with the exhaust manifold hot makes it come out a little easier. Make sure you stick with a stock delco brand.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-30-2009, 01:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Help
Welcome to AF.
Will it idle when you disconnect the pre CAT 02 sensor electrical connector? The 02 sensor is really not used at initial cold engine startup and until the engine has warmed up sufficiently and ready to go into closed loop mode from open loop mode.
On brand of 02 sensor the Denso brand works fine too.
Timeslip 08/12/06
AF Community Guidelines
Old 04-30-2009, 07:23 PM
tblake's Avatar
In God We Trust
Re: Help
I knew there was another brand that was good to go Bob. I just couldnt remember for the life of me what it was... delco, denco, bosch.... so I didnt mention anything.
Thanks for clarifying.... denso.
Old 04-30-2009, 07:41 PM
BNaylor's Avatar
Re: Help
Oh Oh Tim. You said the "B" word. Watch out for Rich. Hide!
Timeslip 08/12/06
Old 04-30-2009, 07:45 PM
doctorhrdware doctorhrdware is offline
Re: Help
He gets 10 demerit points.
Old 04-30-2009, 08:24 PM
tblake's Avatar
In God We Trust
Re: Help
10 more? really? Ah Man! I dont have many to lose! I'm down to about 30 left.
Old 05-01-2009, 09:33 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Help
Did someone say the "B" word,
You're lucky I like you Tim, or I'd
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-01-2009, 09:47 AM
tblake's Avatar
In God We Trust
Re: Help
OOPS! Sorry Rich, I wont let it happen again!
