Old 04-28-2009, 09:22 PM
prostar14 prostar14 is offline
2001 Ford Windstar - No start, no crank
Just posting this in hopes to help someone.
About a year ago the van started having intermittent starting issues. The starter seemed fine, but I changed it any way. The second starter acted the same. It seemed if you could at least get a few "clicks" out of it, you could just hold the key, and eventually get it to go.
This time it just died and never started again. I went over all the fuses, relays, connectors, neutral safety switch, etc... I finally found that it was the PCM diode. It was rusted and even had jagged edges from arcing. I couldn't find a replacement right away, so I sanded it and it's working like new.
This cost me a tow, and two starters, so I hope it saves someone...
Old 04-29-2009, 08:27 AM
northern piper's Avatar
northern piper northern piper is offline
Re: 2001 Ford Windstar - No start, no crank
where is the pcm diode that you refer to?
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 04-30-2009, 12:34 AM
bdahl385's Avatar
bdahl385 bdahl385 is offline
I would like to know also, my Windstar is 9 years old now and I've never sanded that PCM diode... It's probably way overdue for the service...
2000 Windstar SE 3.8L 125k miles (mine)
2006 Hyundai Sonata LX 3.3L 108k miles (wife's)
2013 Hyundai Elantra GLS 21k miles (daughter)
Old 05-13-2009, 09:31 AM
Sorry, I guess I should have mentioned that it's in the under-hood fuse box, first row (#3 or #4?). It looks like a blade fuse, but one blade is perpendicular to the other.
bdahl: I don't think this need regular service. I only sanded mine because I couldn't find a replacement locally. It's a $5 part (should be $.50).
Old 10-29-2012, 05:10 PM
tsoprano tsoprano is offline
Prostar, I don't know where you are...but man oh man, you saved me alot of time and headaches...if we ever cross paths...I owe you a beer...thanks the problem was exactly the diode...according to the ford diagnostics it looked to be the PCM..but it wasn't...I was minutes away from ordering a PCM until I decided to look up some 'google' info to see if others have had the same problem...thank God and thank Prostar!!
Old 10-30-2012, 11:10 AM
I'm over in Ottawa. No beer needed, just pay it forward and post follow-ups when you find solutions. There's nothing I hate more than finding my problem described exactly on the web with no follow-up.
Old 10-23-2017, 11:55 AM
JCD75 JCD75 is offline
Smile Re: 2001 Ford Windstar - No start, no crank
Works like a charm. It is in position 501 on a 2001 Windstar. The cover of the power distribution box is tricky. There is only one catch on the back side on the left. Once you reach in and get the bottom of it it releases but takes some pressure and patience, I found one terminal rusted and corroded. Took some sanding, I finally used a fine file also since both surfaces are hard to get to. I put it back twice before it was clean enough to make contact. A small amount of WD40 helped.
Tags
"no , "pcm , clicking , power" , start"
