Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-28-2009, 06:48 PM
TommyRocker TommyRocker is offline
02 LS intake swap problems
I have an 02 LS with 160,xxx miles. Never had any problems or work other than oil changes and assorted filters. Recently developed the intake leak. I replaced the upper intake with the Dorman's kit. Now it is running like trash. It seems to be missing like crazy. All the injectors seem to be working. I held a piece of steel up to them and can hear them all clicking. It ran nice until the leak started. Then it started hard and idled weird and so on, but nothing like this. Before it would pull hard and everything, so this only happened after I swapped the intake. Any ideas are appreciated.
Old 04-28-2009, 09:23 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 02 LS intake swap problems
3.8 liter?
Did you install the new pcv valve? There is an o-ring that goes around the PCV valve and one that goes on the cover.
Old 04-28-2009, 09:29 PM
Yes. PCV is installed, with new O-rings. I uninstalled it re-installed it to be sure. Thanks. Think I should pull injectors and clean them?
Old 04-28-2009, 09:40 PM
Airjer_'s Avatar
No missfire codes or codes in general?
Old 04-28-2009, 09:41 PM
Airjer_'s Avatar
maybe a plugged catalytic converter?
Old 04-28-2009, 10:03 PM
new cat....and it only happened once I got it back together...seems to indicate I screwed up....just not sure how
