Go Back   Automotive Forums Car Chat > Hyundai > Accent | Verna
Old 04-28-2009, 05:15 PM
kurkam2 kurkam2 is offline
accent flooding
my 2000 hyundai accent is flooding,rough idle,black smoke,scanner says coolant temp sensor could this really make her work so bad ,will shut off without a little pedal,cant make it up hills so stuck without a long tow
thank you for any reply
Old 06-15-2009, 08:03 AM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: accent flooding
No, it's not the coolant sensor. Probably 2 different problems not related.
Check oil, to see if it has gasoline present with the odor test. Check cylinder compression, it's often bad piston rings. Have you used injector cleaner? Don't use.
Check also antifreeze color. If it's brown, it's bad sign.
Check upstream oxygen sensor, injectors, MAF & MAP sensor, PCM, sparks, vaccum leak, IAT.
It can be a lot of things that cause this common problem.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
