Old 04-28-2009, 02:45 PM
dutch05 dutch05 is offline
2002 Grand Am GT Clicking Problem
I have a 2002 Grand Am GT that has treated me very well. However for quite a while now i have a clicking sound coming from the steering wheel area. It sounds like your turn signal but at a faster rate. It also comes and goes, its not always constant. Anyone have any advice? Thanks!
Justin
Old 04-28-2009, 05:23 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 2002 Grand Am GT Clicking Problem
Welcome to AF !!
Could be your muti function switch-MFS or your hazzard relay is bad.
Since its only doing it intermittantly Id lean toward the MFS.
Usualy a cleaning of the contact points works. Then installing new dielectric grease.
Ok, I didnt find the right one for you, so I just whipped a R&R for this.
1999-2005 Multi Function Switch-MFS
Hope that helps!
1999 Grand Am SS 3.4 OHV
Old 04-29-2009, 11:13 AM
Thanks I'll give that a try! Thanks!
Justin
Old 05-17-2009, 12:10 AM
stoynuts stoynuts is offline
Not sure if you still have the problem but I had this problem, the dealer sent out a bulletin for this, they replaced my flasher which is attached to the back of the hazard switch. so it sounds like it is in the dash. But I ended up having to change my multi function turn signal switch very easy to do. The contacts were wore out and shorting out.
Old 05-17-2009, 10:00 AM
Thanks for the tip.
Yes GM did post a TSB for the hazzard relays. Im pretty sure it only coverd 99-01 N bodies and then the relays were made different(better).
Also the MFS clicking can be fixed without replacing the switch. Usualy a cleaning of the contacts and regrease solves this problem. (see post #2)
