Old 04-28-2009, 02:41 PM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
Rattle Noise 00 blazer
Alright i posted about a weird noise from under the dash. a few of you said vaccum hoses and pcv valve. Sure enough the noise was comming from the pcv. and the vaccum hoses were crimped and dry rotted. I replaced all the bad hoses and the pcv. Noise went away for a day and now its back! is this a warning to a bigger problem in the motor? is something wrong in the valve cover?
Old 05-01-2009, 09:17 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Rattle Noise 00 blazer
Just to be sure the blend door motor isn't acting up, does the noise change if you slowly change the heater temperature? What if you change heater fan speeds?
I read that with the motor stone cold, if you park so the front/passenger side is at a higher elevation than the rear/drivers side, the cooling system can be "burped" which helps get rid of any air trapped in the cooling system. Take the radiator cap off and let the engine warm while you keep topping off the radiator coolant level. While you're at it, you might install a new radiator cap to be sure you're not hearing the 'ol junk radiator cap gurgle".
