Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-28-2009, 12:38 PM
Sweden1979 Sweden1979 is offline
Cool Some questions
Hello!
I have some questions about my
Pontiac Trans Sport SE 3,1 1990.
1# When I been driving for about 20 miles the
gearbox locks itself in the third gear & it wont
shift down. I have to shift down to second
gear manual. But when I drive shorter distance
like 5-10 miles it works perfektly. What can it be?
2# How mutch ATF oil shall I put in
the transmission when I change the
oil & filter?
Best Regards
Kenny, Sweden
Old 04-28-2009, 02:00 PM
LMP's Avatar
LMP LMP is offline
Re: Some questions
2# How much ATF oil shall I put in
oil & filter?
Drain and refill (just dropping the oil pan): 4 qts.
Full overhaul (dry transmission and torque converter): 7qts
1# ... when I drive shorter distance ke 5-10 miles it works perfektly.
Temperature dependant, then...THe manual does not describe that condition.......it can be any sticky component, O-ring, seal, debris..hard to pinpoint. When you drop the oil pan, pay attention to presence of debris...maybe fresh new oil could modify the sensitivity to heat...otherwise, hope it goes away, or endure..or control valve surgery...keep us informed of development
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-28-2009, 03:26 PM
Re: Some questions
Hi!
Thanks for the fast answer
You have to excuse my bad english.
I'm going to test to change oil & filter and put some Wynns AutomaticTransmission Treatment in it and se how it runns I'm
also going to put in a seperate oil cooler.
I just read in the autorepair forum that it also could be the TCC solenoid
(Torque Converter Clutch Solenoid).
But first I'm going to test changing the oil & mount the seperate oil cooler
this weekend.
Old 04-28-2009, 06:11 PM
LMP's Avatar
LMP LMP is offline
Re: Some questions
Originally Posted by Sweden1979 View Post
I just read in the autorepair forum that it also could be the TCC solenoid.
Yes this is a known occurrence...but the symptoms would be different than those you described. It generally causes the engine to stall when coming to a stop......So..if you change your description, check this out:
http://www.automotiveforums.com/vbul...d.php?t=551757
Old 04-28-2009, 11:04 PM
Electric_mouse Electric_mouse is offline
Re: Some questions
Would this unit have the transmission lockup solenoid like my 89 Celebrity? Common problem I'm told. I'm told you can defeat it by disconnecting the wiring which will lower your gas mileage somewhat or go a step further and install an underdash switch in the circuit which you operate when coming to a stop. It was easy and best enough to change the lockup solenoid though and not really expensive either. On the Celebrity access through the left wheel well. I had to take the motor mount off.
Old 04-30-2009, 01:12 PM
Smile Re: Some questions
I tried to disconnect the TCC solenoid & now it works. I'm going to order a new next week and change it.
Thanks for the quick answers =)
Pontiac Trans Sport SE 3,1 -90
Tags
atf , gerarbox , oil
