Old 04-27-2009, 05:47 PM
goodoldpapa's Avatar
goodoldpapa goodoldpapa is offline
Code PO404
Check engine light came on today. Stopped by Advance Auto to get scanned and it came up PO404. Looked up and it said EGR circuit, open position performance problem. Car has 144,500 miles. Appreciate any input or suggestion any of you may have.
Old 04-27-2009, 10:58 PM
discnik discnik is offline
Re: Code PO404
If you have a 1996 with a 3.1 L it is:
Egr flow pintle position was over 15 % different than the desired position commanded by the PCM.
If you have a 1999 with a 3.4L it is a 20 % difference.
Basically it could be the EGR pintle position sensor or circuit, or EGR valve or solenoid. Should have a TECH that you trust troubleshoot it.
The above information is from MPC Smart Spec 2003.
Old 04-28-2009, 05:17 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Code PO404
Yeah your engine size and year should be listed.
But either way Id pop the EGR off and look into the intake, the exhaust tube for carbon build up. Clean those out with some carb cleaner and or whatever to scrape the build up out.
Then see if it clears up.
If its a 1999+ grand am I have a test procedure for the EGR in the Tips and Maintenance subforums.
1999 Grand Am SS 3.4 OHV
Old 04-28-2009, 06:50 PM
Re: Code PO404
Sorry about that. It's a '03 with a V6 3.4 L engine.
Old 05-02-2009, 04:05 AM
Re: Code PO404
SES light came back on yesterday, same code, so I'll definitely be taking a closer look at the EGR valve now.
Old 07-17-2009, 08:09 PM
Re: Code PO404
Wound up replacing the EGR valve about a week after my last post. Also sprayed carb cleaner to clean around the area also. Code has not come back. About a week later, though, code P0300 came up. Replaced the spark plug wires and that took care of that code, hasn't reappeared since.
Old 07-18-2009, 05:31 PM
Re: Code PO404
Glad you found/fied the problem !
Old 07-18-2009, 08:36 PM
Re: Code PO404
Thanks. My wallet is glad also
