Old 04-27-2009, 01:19 PM
drw7162 drw7162 is offline
Cruise Control Not Working
I searched on this topic and couldnt find anything, so if its been answered I apologize, but I here I go. I have a 2001 GMC Jimmy SLT and the cruise control only works once in a great while, most of the time it does not. Why is this? How can I troubleshoot this? I have checked the fuses and all are fine. Is it the switch?
Old 04-27-2009, 01:26 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Cruise Control Not Working
Check the Vacuum lines for leaks and disconnects. If I remember correctly, there is a vacuum line that runs into the driver's fender and connects to a vacuum cannister inside the fender. Make sure it isn't cracked split or dry rotted.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 04-28-2009, 07:27 AM
Thanks for the info, I looked at all the hoses and wires and did not find anything. I even followed the haynes manual for troubleshooting the cruise control and found nothing.
Old 04-28-2009, 07:57 AM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
could the multi-function switch be bad?
Old 04-28-2009, 08:27 AM
I see online there is a recall on that switch for my year jimmy. Can that affect the cruise control?
Old 04-28-2009, 02:33 PM
IT very well could be your problem. the multi-function switch is the whole assembly for the hazard switch and the turn signal/wiper/cruise control lever. I replaced mine before i knew there was a recall bc my brake lights were not working. so it controls alot. hence the name multi-function
