Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 04-27-2009, 08:16 AM
dtdodd dtdodd is offline
Exclamation Illumination Fuse Keeps Blowing 1998 Breeze
I just installed a radio. I uses a wiring harness adapter which was missing the ground wire. I pulled the pin from an old apadter and put it into the adapter harness. The radio works great but the illumination fuse keeps blowing.
Does anyone what is causing this?? Could it be that the radio is still not properly grounded??
Old 04-27-2009, 10:17 AM
ricebike ricebike is offline
Re: Illumination Fuse Keeps Blowing 1998 Breeze
guess so; try to just wire a ground cable directly to a chassis instead of using that pin
Old 04-27-2009, 01:03 PM
Thanks. I will give it a try and let you know.
Old 05-01-2009, 10:05 AM
The ground was the problem. Thanks
