Old 04-27-2009, 08:02 AM
mikeyDep mikeyDep is offline
temp sensor?
91 4.3l
stalls while driving, only seems to do it after it's warm.
starts fine, idles fine, runs fine...then stalls....
is this the temp sensor?
it doesn't overheat.
going to replace it today...and see what happens...
new fuel pump and filter installed about a month ago...
thanks for any help
mikey
Old 04-27-2009, 10:31 AM
ricebike ricebike is offline
Re: temp sensor?
read trouble codes?
http://www.troublecodes.net/GM/
hmm the only 4.3 L engine i see on that list is for a 1992+
http://www.troublecodes.net/GM/92-93_43Z_tbi.shtml
Old 04-27-2009, 12:20 PM
Re: temp sensor?
no trouble codes flash...
only the 12...which means it's working....
going to install the new temp sensor now....
this is a 91 jimmy sle with 4.3l v6 engine
Old 04-27-2009, 01:35 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: temp sensor?
Originally Posted by mikeyDep View Post
91 4.3l
thanks for any help
mikey
Don't just throw money and parts at your truck. My 93 did the same thing and my issue was the distributor module. The distributor module is the little piece under the distributor cap, below the rotor that is screwed to the base with a couple of screws and has approx. 3-4 wires connected to it. Anyway, Some auto parts stores can check these off of the vehicle. You might want to take yours off and have it checked before buying a new one, once you buy a new one they normally won't refund your money. Be very careful as the connectors can be very brittle.
The auto parts stores will tell you that the distributor module will either work or they won't and the temp has nothing to do with it. That is Bull***t, my 93 did it to me twice exactly as you described, only when hot, once it cooled off it started right up.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
