Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 04-25-2009, 02:47 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
89 Lebaron issues
Hey there, a buddy of mine recently purchased an 89 lebaron with 90k on it. it has a 4 cyl, pretty sure no turbo...not exactly sure how big the engine is...ANYWAYS, the engine seems to run pretty good, smooth at least at idle, revs up nicely...but when driving, it picks up really slowly, and it seems to kind of mis-fire and buck around as your trying to accelerate....It's a pretty slow acceleration tho....Any info about this would be fantastic thanks!
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 04-25-2009, 05:16 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 89 Lebaron issues
Timing!
I'd start with a timing light and see if the timing is right. If its off and nobody has played with the distributor then I would check the timing belt to see if 1 its in good shape and 2 if the timing marks are lined up.
Old 04-25-2009, 06:10 PM
XGamesJ6's Avatar
Thats what i thought, timing is off....But my friend thought it was all within the tranny, he put some lucas trans additive, and he's saying it runs a lot better....I tried break torquing it....and It didnt seem to be low on power at all....Do you know if I can rent a timing light from AZ?
Old 04-26-2009, 07:53 PM
Scrapper Scrapper is offline
AF Premium User
maybe he had dist out and got it a tooth or to off when he put it back in? i'd get it up on number one plug then see if rotor is pointing to number one in dist cap..
Old 04-27-2009, 06:00 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Also, just FYI, if it doesn't have a turbo then it's a 2.5L.
