Old 04-25-2009, 01:05 PM
hendrix3511 hendrix3511 is offline
Exclamation UPDATE: Flashing dash on startup, accompanied by dieing randomly
It was the fuel filter. Even though a fuel pressure test was normal. My local mechanic says that sometimes it has pressure but little volume. When I took the old filter off, I couldn't even blow through it. I put it on yesterday and have not had any of the previous problems.
I still only have 30 psi with engine off, ignition on. Alldata says 41-47 psi. Should I worry if there are no symptoms? Would I replace the fuel pump next or the pressure regulator?
Thanks
Old 04-26-2009, 01:09 AM
harmankardon35 harmankardon35 is offline
Re: UPDATE: Flashing dash on startup, accompanied by dieing randomly
just had a 02 alero that did the same thing...hard to start up...fuel pump quit soon after turns out the filter was heavily clogged, which ultimately burned out the fuel pump. Id look into the pump just so you don't end up on the side of the road. If the fuel filter was that clogged, it means that pump has been struggling for some time...
Old 04-28-2009, 05:09 PM
Well I replaced the fuel filter and then the ignition switch and my problems have been solved. I never thought that the ignition switch could cause such a myriad of symptoms. From intermident (sp) turn signals to dieing randomly.
Old 04-28-2009, 06:47 PM
droyalone droyalone is offline
Hendrix3511:
Did you replace the ignition switch or did you get someone to do it? The dealer told me it would cost $700 to replace the ignition switch. I have had the ignition switch changed 3 times on this car and the most in the past was $300. Needless to say that dealership went out of business.
Old 04-28-2009, 07:09 PM
intriguehatesme intriguehatesme is offline
Originally Posted by droyalone View Post
Hendrix3511:
from what ive read here i think you will be able to replace it yourself if you have some tools, a lil know how, and some time.
check this link for instructions in the second post
http://www.automotiveforums.com/vbul...d.php?t=736656
look at me, my second day and im helping people!!!
