Old 04-25-2009, 10:45 AM
Allegretto's Avatar
Allegretto Allegretto is offline
Send a message via Yahoo to Allegretto
Question no power to them wheels....
i have a 97 lesabre custom and i have a pickle i been dealin with for a while. for some odd reason, when i first start the car up i get the normal power i would get from the series 2 3800. but after a few min the power suddenly goes away after the engine heats up. i was told it could be a clogged fuel filter. should i remove the filter and if i do how do i check for clogs and if there is a clog how do i remove it or should i just replace it?
Old 04-25-2009, 12:54 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: no power to them wheels....
Just replace the filter if it has been over 30K miles since the last replacement. Also check fuel pressure when engine is warm. IIRC, the 97 had a recall on the fuel pressure regulator, has it been changed?
Old 04-29-2009, 12:52 PM
Allegretto's Avatar
well thanks becuase i didnt know about the recall! ill def change the filter and the oil pressure is always low once the car heats up though. anything else ill b glad to hear about thanks a lot!
