Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 04-24-2009, 10:37 PM
Bad86MonteSS's Avatar
Bad86MonteSS Bad86MonteSS is offline
Send a message via AIM to Bad86MonteSS
drive shaft question
i'm planning on installing a turbo 350 and a jegster crossmemeber for it into my 1986 Monte Carlo SS.it has the 200r4(or 2004r) in it right now and the 305ho,but i'm also changing to a 355.some my question is..........do i need a different shaft using the aftermarket crossmemeber and the turbo350?? someoe told me i didnt.i want to double check befor ei go do this and find out i fuc*ed up.lol
drive until the road ends or you run off into the sandbox at the end of the dragstrip.lmao
www.myspace.com/smalblok355
http://public.fotki.com/smalblok355/
Old 04-25-2009, 09:56 AM
MrPbody MrPbody is offline
AF -Advisor
Re: drive shaft question
Are you sure it's a 2004-R? Or could it be a 700R-4? Most small blocks got the 700, though I HAVE seen a fw with 200..
Anyway, measure from the bellhousing flange to the tail (a tape meaure is good enough for this). I believe they're the same for TH350 and TH2004-R, but I could be wrong (wouldn't be the first time...). The slip-yoke should be the same.
Jim
Old 04-25-2009, 05:30 PM
it is a 200-4r.....because i checked the oilpan on it.lol.they're both the same length the th350 and the 200-4r. all the aftermarket crossmember doe sit relocate the trans mount poit back 6inches for the th350 mount.
