Old 04-24-2009, 08:36 PM
themadride themadride is offline
Question 97 S10, broken hazard switch
Oh boy. I have a big problem that I'm hoping has an easy solution.
My hazard switch broke off and is also lost. This would not be a big deal but the hazard lights are currently "on".
I know that replacement involves the entire signal switch assembly. I really don't want to replace it.
Is there any way possible to turn off (disable) the hazard lights so I don't have to disconnect the battery cable every time I turn off the truck?
Thanks.
Old 04-24-2009, 11:45 PM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: 97 S10, broken hazard switch
Not sure what the hazard switch in a 97 S10 looks like but i owned a car that was missing the switch and found that a fine point perm marker fit into the hole perfect to turn off the hazards. Infact i actually cut off the end (oppisite side of the marker tip) left about 1 1/2 to 2" and jammed it in there and made a new switch worked great and always passed safty inspections.
not sure if this helps any but its an idea.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 04-26-2009, 10:20 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
In the "How-to" section of the Blazer forum, is a thread on how to replace the broken hazard switch.
The pics aren't showing for me, but in essense, what you do is take a needle nose plyers, and pull the broken switch straight out.
Pulling out the broken switch should stop the flashing.
Pop in a new switch (only available from GM dealers - I think), fixed.
Here's a link with the GM part number. Chevy, buick, or Pontiac dealers should carry them. Call your local dealer.
http://www.automotiveforums.com/vbul...d.php?t=558992
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 04-26-2009, 04:35 PM
blazee's Avatar
blazee blazee is offline
Problem?
http://www.automotiveforums.com/vbul...d.php?t=595263
