Old 04-24-2009, 06:40 PM
stealth98682 stealth98682 is offline
Exclamation 92 Stealth Throttle sticking??
I am not sure exactly what the issue is. I just had a ECU put in couple weeks ago(for reason of car not starting). But now if I let the RPM go up to a certain rpm the throttle will stick and the speed will continue to rise and if I have it in nuetral or clutch in the rpm goes sound like its red lining. If I restart the car its still stuck in full open throttle. But I have to manually move the lever back then its ok till I hit that rpm again. My RPM gauge doesnt work since AAmco forgot to put it back in. Please help I am very confused
Old 04-24-2009, 07:29 PM
quackmandude quackmandude is offline
Re: 92 Stealth Throttle sticking??
sounds like ur throttles sticking, it happened to me a few times. i greased the throttle cable and make sure its good going throught the cruise control box,. it could be a dirty throttle body or valve check it and clean it out
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 04-24-2009, 11:17 PM
thanks i wd40 the cables and around the box- looks pretty clean but dang thing still does it but only does it when i am driving.
Old 04-25-2009, 12:30 AM
have u checked the throttle bod?? it may be dirty. also the throttle pos senser could be the culpret
Old 04-25-2009, 12:55 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Make sure your mat isnt getting stuck against your pedal.
