Go Back   Automotive Forums Car Chat > Pontiac > GTO > Classic GTO's (1964-1974)
Old 04-24-2009, 06:34 AM
pete1027 pete1027 is offline
Question starter cable shield
I have been reassembling a Pontiac 400, and have been trying to figure out where to bolt the heat shield that wraps around the wires that go from the battery to the starter. Thanks.
Old 04-25-2009, 10:00 AM
MrPbody MrPbody is offline
AF -Advisor
Re: starter cable shield
Pete,
Are you talking about the tube the cable runs through to avoid the exhaust manifold? If so, there should be a "studded" head bolt in the 4th one back (one of the "short" bolts) on the left (driver's) side. The loop goes over the stud and is secured with a 3/8-16 nut. If it's a Ram Air engine, it's different. The tube attaches to the back of the head and the cable "sneaks in" under the back of the manifold.
Jim
Old 04-26-2009, 08:58 AM
That was what I was talking about. Thanks. I couldn't figure out how to get it to fit on there, but knowing that that is where it should go, I'll find a way. Maybe the tab got bent on the heat shield.
