Old 04-23-2009, 07:16 PM
Notator Notator is offline
radio silence
99 Taurus radio that has no display and no sound,all other radio lights work just not in the display, have checked all fuses on the panel and under the hood,have replaced actual unit three times and all with the same luck,none,though all units were used and supposedly worked
have read previous posts about the same problem but no success stories,if anyone can help with the silence i would be grateful
Old 04-23-2009, 10:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: radio silence
Welcome to the forum!
The sound is actually provided via the Rear Control Unit (RCU) and not the dash unit. So you might have two issues, something causing the display to not work, and something with the RCU preventing sound. If you insert a tape or CD do they seem to spin and eject fine? Do the replacement units work for a short time, or not at all upon installation? Do you have the pinout to verify you have power and ground where you need power and grounds? The button illumination is from the dimmer and independent of the radio power circuits.
-Rod
Old 04-24-2009, 02:18 PM
Re: radio silence
Thx for your answer but none of the units showed any signs of life at all and now i have a cassette stuck and no motor kicked in and where in the trunk is the RCU,looked all over and can't find it
Old 04-24-2009, 04:42 PM
shorod's Avatar
SHO No Mo
Re: radio silence
It definitely sounds like you're missing power to the deck. That helps narrow things down. I'll take a look at the wiring diagrams for the deck this weekend and try to post them for you.
As for the RCU, that's probably irrelevant at this time, but it is located on the driver's side of the trunk, near the floor. It will be behind/underneath the trunk liner on the driver's side.
-Rod
