Old 04-23-2009, 08:07 PM
Smith1000 Smith1000 is offline
97 Lesabre AC Leak
Well, it is almost that time again as it reached 80 degrees here today and the Lesabre AC is not holding a charge. I ran some dye through it and found that it is leaking profusely off the very front portion of the compressor. It is slinging so much out that the dye is on the underside of the hood and everywhere else in between.
How do I stop the compressor leak? Should the front plate come off for a seal replacement, or should I get a new compressor? Does the compressor need to come out of the car for the fix? What parts are needed? It does get very cool when it is working, but I am sure that there will be no freon left by tomorrow. Thanks.
Old 04-23-2009, 09:43 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 97 Lesabre AC Leak
Typical shaft seal leaker...Either find someone who can change the seal- or splurge for a new compressor.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 04-23-2009, 09:49 PM
Thanks. Do auto parts stores sell shaft seal kits?
Old 04-23-2009, 10:12 PM
Scrapper Scrapper is offline
AF Premium User
they should cary the compressor if not it would be dealers item. check nappa or carquest if you got them parts stores around you? if not let it run out and unplug the compressor. sometimes salvage yard could have one new or like new....good luck....
Old 04-24-2009, 06:31 AM
Thanks. I would sure prefer to replace the seal in what I have-if I can find the parts.
Old 04-24-2009, 10:26 AM
brcidd's Avatar
Shaft seal kit is sold anywhere a/c delco parts are sold-
A/C delco part # 15-30948
or GM part number 2724954
But you will need some special tools you can borrow at Autozone....
'99 GMC Yukon
Old 04-25-2009, 06:40 AM
Thanks. This really helps. I'll track down a seal kit and pull the compressor.
