Go Back   Automotive Forums Car Chat > Mercedes-Benz > C-Class
Old 04-23-2009, 07:32 AM
naderson naderson is offline
Any C230 Kompressor Tips?
Dear All,
I just got a 2003 C230 1.8, and would like to know if you have any tips from experience.
the car seems mechanically fine, i will perform a general check-up soon.
Old 04-27-2009, 05:36 AM
Re: C230 Kompressor Tips More Specific.
Okay. i will be more specific.
1. what is the proper inflation pressure of the tire? is 30 psi optimum?
2. what engine oil is best for this car. i know mercedes approves moible, and i know the best is synthetic, but what type?
3. the panoramic cover suddenly stops functioning properly. it moves only 5 cm per push. what could be the problem?
Old 04-27-2009, 03:59 PM
eclass eclass is offline
Re: Any C230 Kompressor Tips?
set the tires to 32 psi.
use the best oil out there, 5w-40 or 0w-40. the back of the bottle MUST say MB approval 229.5
push and hold the sunroof switch in the "pop-up" position until the roof is all the way opened. Continue to hold the switch for 5 seconds after the roof is opened. this should relearn the motor position.
Old 04-28-2009, 12:29 AM
Thumbs up Re: Any C230 Kompressor Tips?
Thanks a lot..
The roof works.
regarding the tire pressure i found out that the front shall be 28 and the rear 32..
thanks as well for the oil..
