Old 04-23-2009, 04:22 AM
goodoldpapa's Avatar
goodoldpapa goodoldpapa is offline
Stumped at the moment
My 03 is experiencing loss of power when I have to climb hills. The following maintence has been done recently.
11/08 - Transmission fluid & filter change
01/09 = Replaced oil sending unit
02/09 - Replaced LIM, UIM, & valve cover gaskets. Also replaced spark plugs and fuel filter.
03/09 - Replaced air filter
04/09 - Replaced spark plug wires & ignition coil packs. Also replaced serpentine belt & belt tensioner.
The only regular maintenance that is overdue is replacement of O2 sensors. The car has 144,300 miles on it. Replacement of LIM gasket % oil sending unit took care of leaks. A couple of friends have suggested possibly the catalytic converter. The SES light is not on. The only time it was on was right before the replacement of the gaskets and has not been on since. Appreciate any help or suggestions you all may have.
Old 04-23-2009, 07:47 AM
3100 3100 is offline
Banned
Re: Stumped at the moment
what is the sea level of the hills?
every 1000 feet above sea level you will loose 3% of your engine's power since the air is less denser as you go up and therefore AF ratio will be affected.
Old 04-23-2009, 02:19 PM
Most are around 1000 ft but up toward wher my stepdaughter and & her family live its around 2000-2500 ft. I understand that you lose some but this is more than what would be considered normal.
Old 04-23-2009, 06:23 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
I think these newr models arent affected by altitude to much.
Thier are sensors(Altimeter/Barometer?) that keep it in the right air fuel mix.
Thier were issues with the 2003 Converters. Id get that tested.
Was it doing anything else out of the ordinary ?
And was it doing this before the trans fluid/filter change, or jsut recently ?
1999 Grand Am SS 3.4 OHV
Old 04-23-2009, 07:28 PM
It was doing it before trans fluid/filter change. Gas mileage is down by 20% also.
Old 05-26-2009, 01:31 PM
Still has the loss of power and hesitation when accelerating. gas mileage is off by about 25% now. Most of the responses I have received on here as well as from friends & family point toward the converter. I wish for once the SES light would come on and tell me that (converter). It's kind of aggravating when you know you have a problem but can't pinpoint it 100% and SES light won't come on. The only time it came on was about a month ago for a EGR-related issue ( hasn't been back on since).
Old 05-27-2009, 04:32 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
Don't count on getting a SES light for the converter. My converter was plugged to the point that the car would barely start and I never even got a SES light. I would get the O2 sensor readings thats how it was determined that mine was bad.
Old 05-27-2009, 05:24 PM
racer77 racer77 is offline
the hill probablyy has nothing to do with it. if your on flat and mash on the peddle, it will do the same thing.
the converter sounds like a good guess.i mean , its not a huge job, so i would try that.
Old 05-27-2009, 08:12 PM
Does it matter as far as the brand? Everyone in my area carries Walker except for Autozone, which carries Magnaflow.
Old 05-27-2009, 08:39 PM
grfnkl's Avatar
Honestly go with the one that has the longer warranty on it. You should be fine with magnaflow though. If you put a cheap converter in it will just go bad in a matter of months again.
Old 05-27-2009, 10:33 PM
Ok thanks. I did notice that the magnaflow at AZ had a 5 yr warranty.
Old 05-28-2009, 07:07 AM
Banned
Let us know if converter got it fixed.....
Old 06-01-2009, 01:52 PM
That is on my to do list as soon as I can get the $.
Old 06-01-2009, 02:00 PM
Banned
or you can try straight pipe in between when you remove the cat just for the test.
Old 07-17-2009, 08:02 PM
Haven't got the converter fixed yet but replaced my front O2 sensor about a month ago. Gas mileage went from 22-23 mpg to 27-28 mpg. Also cleaned my MAF sensor earlier this week and car accerlerates a lot smoother. Didn't look dirty but went ahead and cleaned it since I went to the trouble of removing it to check. Used CRC MAF Cleaner.
