Old 04-23-2009, 12:02 AM
justinharry1 justinharry1 is offline
Rear Wheel Hub/Bearing Removal
Im having some serious trouble getting of my rear wheel hub/ bearing assembly..ive removed everything and i cant get the hub to remove...can anyone give me a guide or detailed instructions? Dont no to much bout it im only 16 so try to make it simple ha but i did the front and dint find it to difficult. 99' grand prix gt thanks!
Old 04-23-2009, 12:43 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Rear Wheel Hub/Bearing Removal
Depending on your location, it may be rusted badly. Use plenty of PB Blaster and a big 5lb hammer.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-23-2009, 10:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
if that doesn't work, use a 10lb hammer....
You can also try carefully using a chisel between the hub flange and spindle to get it to break free. Just be careful so you don't gouge up the mounting surface on the spindle
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
