Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 04-22-2009, 05:20 PM
bub48161 bub48161 is offline
codes P1131 P1151 and P0171
ok i have 3 codes that come up when i put it on a code scanner and i need to know how or what i should do to fix them and if theres away i could clean parts or something so i dont have to replace them that would be good to or any info what help out alot
p1131 which is Ho2s lack of switching bank 1
p1151 which is Ho2s lack of switching bank 2
p0171 which is fuel system lean bank 1
Old 04-22-2009, 08:29 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: codes P1131 P1151 and P0171
Sounds like you have an intake leak. If I had to guess its the intake manifold gaskets or a hose is lose.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 04-23-2009, 08:04 PM
yeah i was going to try the carb cleaner trick and see if i can hear it
