Old 04-22-2009, 02:43 PM
heavyredchevy's Avatar
heavyredchevy heavyredchevy is offline
Oil pan gasket?
My girlfriend just bout a 97 Pontiac Grand Prix GT with the 3.8L engine. It has a moderate oil leak, part of which is coming from the rear valve cover gasket, and oil pan gasket. The valve cover gasket isn't hard for me to change in my garage, but the oil pan gasket might be a problem. Any tips/ideas?
Thank you,
Ryan
89 Chevy K1500, Extended Cab, Long Bed, 5.7L, 700r4 tranny, 10 bolt rear
Things Done- Flowtech Headers, Heartthrob Deep Tone Dual Exhaust, Airaid TBI Spacer, K&N Intake, 3" Performance Accessories Body Lift, 285 75 R16 Pro Comp A/T Tires, 16" Americain Racing Outlaw 2 Rims, Fabricated Bumper Replacement.
Old 04-22-2009, 04:25 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Oil pan gasket?
The oil pan gasket is not a easy DIY job. Due to the way the subframe is designed, you have to drop the engine cradle while supporting the engine from above to get it out. I would suggest having that done at a shop unless you have access to a hoist.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-22-2009, 05:54 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Oil pan gasket?
I agree with Rich, for safety reasons, if you dont know 100% what your doing, replacing the Oil pan gasket is better left to the pro's.
Also your car might be covered by a recent GM recall regarding leaky valve cover gaskets. I'm not sure if the most recent recall covers both front and rear valve cover gaskets or if its still just the front. Maybe what to look into it. Your local dealer could give you more info.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
