Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 04-22-2009, 09:09 AM
Alphabravo Alphabravo is offline
P0455 and P1448 Codes, please help.
Hello,
I have a 2003 Max with P0455 (Evap Leak - Large) and P1448 (Manufacturer Control Aux Emission Control) codes.
I've already changed the gas cap and the codes came back. Does anyone have any idea what it might be?
Thanks in advance.
Old 04-23-2009, 06:15 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: P0455 and P1448 Codes, please help.
Originally Posted by Alphabravo View Post
Hello,
Thanks in advance.
The FSM has following clues, check out page EC-390
DTC P0455 EVAP CONTROL SYSTEM (GROSS LEAK)
Possible Cause
 Fuel filler cap remains open or fails to close.
 Incorrect fuel tank vacuum relief valve
 Incorrect fuel filler cap used
 Foreign matter caught in fuel filler cap.
 Leak is in line between intake manifold and EVAP canister
purge volume control solenoid valve.
 Foreign matter caught in EVAP canister vent control valve.
 EVAP canister or fuel tank leaks
 EVAP purge line (pipe and rubber tube) leaks
 EVAP purge line rubber tube bent.
 Blocked or bent rubber tube to EVAP control system pressure
sensor
 Loose or disconnected rubber tube
 EVAP canister vent control valve and the circuit
 EVAP canister purge volume control solenoid valve and the
circuit
 Fuel tank temperature sensor
 O-ring of EVAP canister vent control valve is missing or damaged.
 EVAP control system pressure sensor
 Refueling control valve
 ORVR system leaks
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 04-23-2009, 08:53 AM
Thanks! That gives me a few places to start.
Old 04-23-2009, 12:58 PM
There seems to be 4 valves and 2 sensors used in ctrl of this function. That means also (not mentioned in the FieldServiceManual) lots of bad connector pin and gnd point possibilities...
Old 04-27-2009, 11:14 AM
I think I found the problem. Thanks to Nahkpohjola for listing all the components for me and to Wallykarp who had a similar problem with a '98 Max.
I looked and all the connections and they all seemed dry and corrosion-free. I then took a closer look at the valve on the charcoal canister, I put 12 volts to it and sure enough it was stuck open.
Problem was that the bolts that held it onto the canister broke so I ended up having to buy a canister too. Ouch! (It's my wife's car, but it it were my own, I would have just gotten some big cable ties and strapped it on to the canister. Since there's an o-ring that seals it, not a gasket, I think it would not have leaked. But for her I wanted it done right the first time and not have to mess with it in the future.)
I'll post again if there's any new, but so far so good.
