Old 04-22-2009, 02:24 AM
CL8 CL8 is offline
Radiator overflow cap came off
I checked under the hood of my '99 Dodge Caravan the other day and found the cap to my coolant overflow compartment snapped off.
Why would it come off?
Is it something to be concerned about?
Thanks
Cl8
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 04-22-2009, 10:35 AM
ricebike ricebike is offline
Re: Radiator overflow cap came off
change out the radiator cap, it seems it's letting the excess pressure out, hinting that the radiator cap is probably worn
Old 04-22-2009, 12:55 PM
CL8 CL8 is offline
Thanks ricebike, I will look into it,
Cl8
Romans 10:9-10
Old 04-22-2009, 01:56 PM
np, hopefully it's just the rad cap... another cause is your head gasket blown & the excess pressure is coming from the engine... going thru your cooling system, and out the overflow...
that can also be checked by pulling the oil dipstick and seeing if your oil is like a milkshake consistency than just regular honey/black colored
hopefully this worse case scenario isn't it
Old 04-25-2009, 02:29 AM
CL8 CL8 is offline
Would my car even run with a blown head gasket?
My engine oil looks like oil, not a milkshake!
Romans 10:9-10
Old 04-25-2009, 04:37 PM
vgames33 vgames33 is offline
It will still run with a blown head gasket, just not very well.
Did you try popping the lid back on and driving around? If it doesn't pop off again, I'd consider it a fluke and wouldn't worry about it.
Old 04-27-2009, 09:36 AM
i agree it may just been a fluke; if the cap fails to hold pressure, you'd also noticed excessive coolant mix spewing out of the resevoir as well
Old 05-01-2009, 10:17 PM
CL8 CL8 is offline
Well I recently checked and the cap hasn't popped off, so maybe it was just a fluke, thanks
cl8
Romans 10:9-10
