Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 04-22-2009, 03:09 AM
weave41_82's Avatar
weave41_82 weave41_82 is offline
Rear Calipers?
I have a 93 GS with 4 wheel disc brakes. Now the problem is, is that if i look for my car specific 2wd the only thing listed is a caliper, rotor and pads kit for the front. Do they not make calipers for the rear, I know that I can find rotors for the rear but having issues finding calipers.
Is it possible to use the awd set up, they come with calipers for the rear in the kit
Old 04-22-2009, 07:02 PM
weave41_82's Avatar
Re: Rear Calipers?
Ive seen that there has been a few views but no input, maybe this will help. I found a website that will accomodate for performance rear calipers but they will make my parking brake inopperable. Does anyone know if there is a way around this, suggestions?
Old 04-22-2009, 09:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Rear Calipers?
I'm too sure on this since I'm not familiar with the 1st Gen brakes. There has to be pads out there. I would say take them off and take them to Pep Boys or something and see if they can be matched up, or even check to see if they're the same size as the fronts.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-22-2009, 09:36 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Rear Calipers?
Im not clear on what your trying to do. Are you wanting to upgrade the rear calipers?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-23-2009, 06:00 AM
weave41_82's Avatar
Re: Rear Calipers?
Well i will start out by saying that Brembo makes a big brake kit for the front including rotors pads and calipers. The rear for some reason is being trick, i can find rotors for them all day long, but finding calipers (upgraded from stock) is proving to be near impossible. Someone on carforums showed me of a brand called TCE that makes a rear caliper for them but only 13 inch rotors. And also these calipers make the parking brake inoperable. Im just not really sure what the problem is here. I have seen kits for front and rear made for awd eclipses. How could i modify my rear brake system to accomodate a big brake kit?
Old 04-23-2009, 08:01 AM
Holset powered 420a
Re: Rear Calipers?
Rear rear brakes from an EVO should bolt right up. You may want to double check that since you have a 1g. Anything more than that and its overkill
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-28-2009, 09:12 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: Rear Calipers?
even the Evos all around are a little over the top... lol (speaking from experience)
