Old 04-21-2009, 08:32 PM
cj7jeeper cj7jeeper is offline
1991 Metro 1.0 L will not start.
I pulled the engine out for a rebuild. Completed and installed engine. I have two wires I have no clue where they go. The two wires look like they could hook-up to the Starter or the Alternator. The two wires look like they would connect to the same connection because they are wrapped together and have the same angle on the eyelets. Please help!
Old 04-21-2009, 09:03 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: 1991 Metro 1.0 L will not start.
I think those are ground wires that attach to the back of the intake manifold. If that is what I am picturing in my head. Do you have any photos you can post?
Old 04-22-2009, 09:43 AM
Thanks for the help with the wires.
I tried a new thing, I sprayed starter fluid in car and son started it. It ran as long as I sprayed starter fluid. I turned ignition on and overrode the fuel relay and the fuel pump pumped fuel. When does the fuel relay request come into play. Is it when the ignition is turned on or is there a sensor that tells the fuel relay that the fuel pressure has dropped and turn on the gas? I also tried a new relay so I do not think it is the relay.
Thanks,
Old 04-23-2009, 12:04 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
if those wires are not hooked to the engine intake as a ground the fuel pump will not come on. also make sure the ground wire behind the rad overflow bottle is connected and tight, should be 2 wires there. one from ground battery cable and another one thats from wiring harness
Old 04-23-2009, 10:40 AM
Thank you, I will get on it when I get home tonight and post the results.
Old 04-28-2009, 11:17 AM
Thanks to everyone for their help! Ya'll hit right on the button with the ground wires.
Old 04-28-2009, 06:20 PM
Glad we could help.
