Old 04-21-2009, 07:25 PM
pfury1978 pfury1978 is offline
Unhappy Caravan keeps going into "anti theft" mode
I have a 2000 Grand Caravan sport and when you try to start it there is a click followed by the lights starting to flash and act as if it is in "anti theft" mode.
If you shut all the doors, unlock-lock-unlock the doors with the key fob it will start and run fine until you shut it off and then have to do it over again. Any help would be greatly appreciated, Thanks
Old 04-22-2009, 12:39 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Caravan keeps going into "anti theft" mode
Welcome aboard. Try disconnecting the negative battery cable a few minutes to reset everything. If that doesn't do it you may need to have the SKIM mounted in the steering column reprogrammed or replaced.
EDIT - Forgot to mention your dealership can read theft system codes with a specialised scanner.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Tags
anti theft caravan
