Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-21-2009, 07:19 PM
gordon_gjs gordon_gjs is offline
AF Non-Newb
catalytic converter Help
Can anyone help me? I currently have code P0420 on my 2003 Impala, it is a 3.8 liter v6. I have tried everything to clear the code. I have replaced both o2 sensors, new plugs and wires and a new catalytic converter last year. I had the catalytic converter replaced at a shop last year and was wondering if they could of put one too small? I will attach pictures of it and see if anybody here can tell me if the cat is too small. And would anyone know if the full bolt on magnaflow cat from autozone should solve the problem?
Thanks for any help I can get!!
Old 04-22-2009, 10:12 AM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Re: catalytic converter Help
Unless you buy an OEM Catalytic From GM (which you have to buy the whole Cat-back part for that, which is probably somewhere around 800 - 900$) Replacing the cat again will NOT fix the problem. The Rear O2 Sensor is very Picky, and even though the Catalytic is probably working fine, the rear 02 is reading values outside the very tight range it would expect from the OEM Cat.
You have 3 Options:
1) Live with the P0420
2) Buy an 02 Simulator (little chip that plugs into the Connector where the 02 sensor connects beside the cat)
3) Have the code deleted from your PCM.
Old 04-22-2009, 11:12 AM
AF Non-Newb
Thanks for you're help Hemi101,
Would you know if deleting the code would let the car pass inspection?
And I saw the forum on 02 sim sensor's, is there one that you might know of that works well and would let the car pass inspection?
Thanks agian
Old 04-22-2009, 11:54 AM
HeMi101's Avatar
In short, a Simluator Technically will get you failed on an inspection, BUT if you installed it really discretely, they probably won't notice it there. I'd suggest the one from www.ZZperformance.com .
You will pass No problem if you have the Code deleted, The PCM just won't know how to throw a code for "Catalytic Inefficiency", which is all the rear 02 Sensor does.
Old 04-22-2009, 12:37 PM
AF Non-Newb
How much does it cost to delete the code form the PCM? And you I assume you would need an expensive tool to do this.
Thanks agian!
Old 04-22-2009, 12:42 PM
HeMi101's Avatar
Thanks agian!
You need someone with a Tuner, like a PowR Tuner or HPTuner. again Sim would be the cheapest route, but might not pass if they see it.
Old 04-22-2009, 12:50 PM
AF Non-Newb
Thanks, I am ordering the part right now!
