Old 04-21-2009, 06:07 PM
gulagman145 gulagman145 is offline
engine revving
I own a 98 caravan 3ltr v6 auto, haven't had any real problems in the four years since I bought it. Turned it on the other day and the engine was revving all over the place. I shifted it into reverse and then drive and the revving continued. My friend says it could be some issue with the throttle body. Any ideas?
Old 04-21-2009, 07:57 PM
tempfixit tempfixit is offline
Re: engine revving
Welcome to AF.
How many miles???
Have you checked for vaccum leaks??
Is the check engine light on???
Have you checked for codes??? Try the key danceon/off, on/off, on within 5 seconds without starting the engine.
Post any codes.
ctwright ctwright is offline
Re: engine revving
Could be a faulty throttle position sensor, this should set a code and your check engine light should come on.
Old 04-21-2009, 10:08 PM
Re: engine revving
The van has about 98k miles, I haven't checked any components yet other than a quick glance at the throttle mechanism while the engine is running. Haven't checked for vacuum leaks, check engine light is not on.
I seem to remember this happening very infrequently just after purchase, it didn't happen again for a couple years that I can recall (until now). No codes.
Old 04-21-2009, 11:16 PM
Re: engine revving
Does it do this with cold engine start up or at normal operating temperature??
Have you tryed cleaning the throttle body and the IAC??
Like ctwright states also check the tps.
Also try disconnecting the precat 02 sensors to see if that makes a differnce.
just my thoughts.
Old 05-01-2009, 10:14 PM
autotech234 autotech234 is offline
Re: engine revving
I would have to say you probly have a major vac leak. or a tps problem
Old 05-20-2009, 08:10 PM
Pakiboi Pakiboi is offline
Re: engine revving
I have the similar problem on my golf 98 mk iv, my engine keeps revving, i went to mechanic he say its the air flow sensor that needs replacing, about £77 from my local shop
