airbag light
i have a 2001 montana and the other day the airbag came on and now stays on. did not hit anything. can someone please tell me why and what or how to fix.
thanks thomas |
Re: airbag light
I had the airbag light on a few months ago, it flashed after turning on the car and did not go off. I unplugged the connector (yellow?) underneath the passenger seat, re plugged it firmly, the light has never come back since then. You can try it, it only takes 3 minutes.
Good Luck! James |
Re: airbag light
Your vehicle will require a scan tool for the proper diagnosis, but here's a site that will explain everything you need to know about airbag lights and resetting the system.
http://www.airbagsolutions.com/ This website gives you the procedure for diagnosing and resetting airbag lights. See if your car is listed here. Although it’s a pay site ($14.95/day), it’s a lot cheaper than going to the dealer http://www.airbagsolutions.com/vehicles_list.aspx On most vehicles, the airbag light should come on for @6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. The flashing light on your car is telling there is a problem. On some vehicles, the light is flashing a two digit code. Once you know the code, you can most likely repair it yourself. There are fairly easy procedures that most people are capable of repairing. Airbagsolutions.com has the fault code charts to tell you what is wrong and how to fix it! Some vehicle manufacturers accommodate systems without a scanner (like Toyota, Lexus, Nissan, Infinity, Honda, Acura, Ford, Lincoln, Mazda & Mercury) . Most all other vehicles require a scan tool for the diagnosis. Check out these websites also for more info on airbag systems and the light. http://blog.airbagsolutions.com/arch...ould-i-do.aspx Lastly, check your vehicle for recalls through this link also: http://www.airbagsolutions.com/nhtsa.aspx
I hope this was helpful to you. My information comes from years of experience in these businesses. http://www.airbagsolutions.com http://www.stolenandrecovered.com Airbag Service, Airbag Replacement, Airbag Diagnostics Thank You, Douglas Gan |
