Old 04-21-2009, 08:54 AM
daman daman is offline
Speedometer reading wrong???
My '95 GT 3100 is reading high(55 on the gauge is 50mph),would this
be a speed senser problem,new one would fix it????
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80
2004 Chevrolet Impala LS 3800
"ALWAYS"...... full synthetic!!!
Old 04-21-2009, 10:04 AM
3100 3100 is offline
Banned
Re: Speedometer reading wrong???
what size are the front tires?
also the speedometer on most GM vehicles are of the air-core design. This is a moving needle operated by a magnetic coil. Since there is no direct mechanical connection, there is some variation in accuracy that cannot be eliminated.
here are some variations at different speeds
20mph variation 4
45mph variation 3
65mph variation 2
according to GM specs any air-core speedometer which reads within these limits should not be returned for service.
Old 04-21-2009, 10:24 AM
Stock low pro tire can't remember the size off hand,but 5mph is allot i think for a variation.
Old 04-21-2009, 02:56 PM
Banned
yes it is too much it should be between 1 and 2 mph according to specs. As you can see you can't do much with it but to replace complete ipc. Or get yourself one of those scan gauges that reads fuel economy codes etc. there you can adjust mph that will be 100% correct since it will get signals straight from VSS.
Old 04-21-2009, 03:22 PM
so changing out the VSS wouldn't help your saying??
Old 04-22-2009, 03:41 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
5 mph is way off for a stock tire, it can probly be adjusted a little with the proper scan tool. That tool can also verify the VSS is working within tolerance.
1999 Grand Am SS 3.4 OHV
