Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-21-2009, 06:27 AM
Sliver97B4C Sliver97B4C is offline
Overheating and Oil Pressure Problems, plz help!
I have a 97 z28 camaro and i've been having heating issues. I just got the heads replaced and it was still running bad. My brother found that the guy didn't get number 5 plug wire on and he put it on. Then he drove it to our house and parked it. I came home ten minutes later and there was antifreeze all over the ground. He said it was never over 210. I let it cool off and filled it up and bleed it. Was going to take it around the block and then come check the tranny fluid. I got halfway around the block and stopped at a stop sign and the oil pressure dropped and it started to die. I gave it gas and it shot back up to 40. It did this when i pulled into the driveway too. I started it the other day and in park it showed 42lbs and then when i put it in Reverse or dirve it drops to the red. any ideas? The car was also shifting hard when my brother and i drove it. He said he got on it and it wouldn't shift to second until he let off the gas. Any ideas on these problems?
Old 04-22-2009, 04:11 AM
Re: Overheating and Oil Pressure Problems, plz help!
I took my car to chevy today and they told me that one of the main bearings is out. Told me my motor is done. They didn't pull the oil pan or anything so does it means its completely trashed?
Old 04-22-2009, 08:58 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
depends on how bad it is usually a rebuild is fairly expensive
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-23-2009, 09:42 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
SLiver,
Please keep to one thread regarding the same issue. Thanks.
