Old 04-20-2009, 01:45 PM
ATC mechanic ATC mechanic is offline
Cool 1999 s10 blazer check engine light
The codes i am getting are:
P1416-Air System (Bank2)
P0410-Secoundary Air Injection System Malfunction
Ne clues or reasons this is coming up?
Old 04-21-2009, 06:56 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1999 s10 blazer check engine light
If you got codes or check engine light on you have a problem.
Code no point to the problem.
In you case and codes the air injection system is not working.
410 IS HOLE SYSTEM AND 1416 IS ONE BANK.
Clear codes and see if they come back.
If so and same codes check out air injection.
FIRST CHECK FOR BLOWN FUSE.
Down in the S-10 how to's there should be some information on 410 codes /problems.
Let us know how it goes.
MT
Old 04-21-2009, 01:55 PM
What fuse should i check
Old 04-21-2009, 01:56 PM
what is the link for the s 10 how to
Old 04-21-2009, 04:49 PM
MT-2500's Avatar
AF - Advisor
The fuse for air pump system.
Down in S-10 forum
On top of it will be the how to section.
In the how to section index go to how to410 code.
Like this
http://www.automotiveforums.com/vbul...d.php?t=564664
MT
