1995 blazer no spark
i put a junk yard motor in and changer dist. over cause it was a flat cap that was in it not the round and also change timimg chain cover so i could put crank sencer in. tryed to start and i have no spark from coil checked all wires, grounds, they are all good were should i do next.
Re: 1995 blazer no spark
Does the pink wire at the coil show battery voltage when the ignition is in the RUN & START positions?
yes i ckecked for power and paulse at the coil and the both show good
If the pink wire at the coil shows battery voltage and the white wire pulses while cranking, and there is no spark from the coil wire, the coil is bad.
You have to know how it works, to figure out why it doesn't. |
thank you i did replace the coil. the one i had was new but must of been bad from the parts store that fix the prob.
Glad you got her going again. Thanks for posting back with the solution!
