94 LeSabre Won't Upshift Under Hard Acceleration
I have a 94 LeSabre. I drive it pretty easy and it's perfectly fine that way. Although when I accelerate hard or push the pedal down and make the car downshift. It sometimes won't shift to the next gear and it'll just stay in that gear for about 7 to 10 seconds. Then usually the "Service Engine Soon" light will come on and it will shift? Anyone have any ideas as to what's going on that triggers this light?
Thanks! |
Re: 94 LeSabre Won't Upshift Under Hard Acceleration
More than likely, you have a quad driver fault in the PCM. Quad drivers supply the ground for the shift solenoids. You could also have a bad solenoid, but it is much cheaper to replace the PCM first. You need to find a shop that still has a scanner capable of communicating with the 94 OBD 1.5 PCM and see what the code is. Typical OBDII scanners will not work.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
How would I got about getting a PCM, I'm going to the junkyard tomorrow. Would grabbing one there be good? Say out of a 1993 LeSabre?
1993 was OBDI and would not work. IIRC, 94 & 95 are the same, but you will need to change the prom and use the one from your existing unit. You will see a cover on the side of the PCM, remove the two small screws & cover to access the prom. BTW, you can get a rebuilt PCM at O'Reilly with a lifetime warranty for less than 100-bucks. Good Luck!
Edit: I found the info on the PCM/ECM you will need; #16183247 LeSabre '94-95 Elec Cont Module (ECM); (6-231, 3.8L) Application: 1994-95 3.8 V6 SFI “L” L27 1995 3.8 V6 SFI “K” L36 1994-95 3.8 V6 SFI supercharged “1” L67 1994-95 truck 3.8 V6 SFI “L” L27 MEMCAL IDs: “L”: BMYU, … “1”: … “K”: … EPROM type: 27C512 16183247
