Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-19-2009, 09:33 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Carb Throttle Linkage options
What are people doing for throttle linkage setups when using a carb? I'm thinking I may need something adjustable to make sure I can get WOT with the current pedal setup. Any comments on the GTS throttle linkage setup?
Thanks.
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 04-19-2009, 10:18 PM
RacingIsLife's Avatar
RacingIsLife RacingIsLife is offline
Re: Carb Throttle Linkage options
i'm not sure what the other versions have, but my GTS has a roughly 3/8" solid aluminum rod threaded on both ends, with reverse threads on one side. small eyelets are used on both ends with locking hex bolts.
to adjust, you loosen the locking nuts and spin the rod.
its an easy setup, is adjustable, and has worked well.
________________
Dan G.
2008 Elan DP-02, IMSA Lites Series
2005 C6 Vette, "Anarchy"
Old 04-20-2009, 06:52 AM
Cobrafang Cobrafang is offline
Jim,
I am headed to Gary Jones Motorsports today my car is there getting work done....it has the carb conversion on the 302. I will snap some pictures of the throttle linkage...etc.
-Tom
Thanks.
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 04-20-2009, 07:04 AM
jmimac351's Avatar
Thanks. If you remember to, ask him whether he had to redo the pedal as well. Another friend here locally swapped to carb on his Panoz but had an issue with the amount of throw available in the pedal. He couldn't get to WOT. He had the Explorer motor and I have the Australian 5.0. It could be that I just need to put on a standard intake mounted throttle bracket. With the GTS using a linkage setup I'm wondering whether you need linkage levers to be able to adjust the range of throw in the linkage to get to WOT with the current pedal.
Thanks.
Jim McGovern
Pictures
Old 04-20-2009, 06:28 PM
Ok the plate is a JEGS part. I am not sure of the part number. There was no modifications required to the pedal assembly. The only thing done was to cut the cable. I took a close up of the connection of the cable to the linkage. A simple electrical connector was used that fit loosely. The cable was fed through the connector then double backed and cut. The heat shrink was used to keep it from fraying. Hope this helps.
Ok I don't know how to post the images. If someone can help me then I will do it. Or send me an email address that can handle 6MB images I will send them to you.
Tom
Racer and Gamer
Old 04-20-2009, 06:36 PM
jmimac351's Avatar
Thanks Tom. I'll send you my email address and I'll post the picture.
Jim McGovern
Pictures
Old 04-20-2009, 06:47 PM
Ok just make sure you are sitting down. The pictures are HOT...and I am not biased at all.
Racer and Gamer
Old 04-20-2009, 07:23 PM
jmimac351's Avatar
Tom, thanks for the picture. I also spoke to Brandon at PAD today and he explained that the GTS linkage is totally different. There is a different pedal that is mounted in a different spot. This changes the throw of the pedal for the carb. There is a stop incorporated to the pedal so you can adjust it for WOT. There is no cable involved - just solid linkage rods. It's interesting how Gary was apparently able to get this to work yet another friend who just hooked up a cable found there wasn't enough throw with the "stock" pedal to get WOT. It doesn't look like the bracket Gary used does anything to change the amount of throw involved.
Jim McGovern
Pictures
Old 04-20-2009, 07:42 PM
Man that is one HOT looking Holley. I get chills just looking at it....
Racer and Gamer
Old 04-22-2009, 10:48 PM
jmimac351's Avatar
It is an inspiration to many.
I ended up getting the GTS pedal setup from Panoz. It's a totally different setup with linkage, etc. I'll take a picture of it so you guys can see what it looks like. It's expensive.
Jim McGovern
Pictures
