Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-19-2009, 08:02 PM
draybook draybook is offline
91 CRX fuel problems
Lately, my car has been choking out. by this I mean that a few weeks ago, I was on my way home from work when I hit the gas and it just died. Since then it's been dying after about 10-15 minutes of running. It smells like it's flooding. When it first started doing this it would idle up and down, generally around 1k rpms. It hasn't really done this lately. Any ideas?
Old 04-20-2009, 02:03 PM
somick's Avatar
somick somick is offline
Re: 91 CRX fuel problems
We need more information about your vehicle: mileage, maintenance records.
As a general rule: check your distributor cap, ignition wires.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 04-22-2009, 11:20 AM
craddock01 craddock01 is offline
Your idle problems could be throttle position sensor
Old 04-23-2009, 10:21 AM
It's getting flooded and my bro in law says it needs to be tuned right. The air/fuel ration is messed up and it's running way too rich, causing it to get too much gas and flood. Anyone have any idea how much it costs to get tuned?
Old 04-23-2009, 04:20 PM
ricebike ricebike is offline
call your local autoshop if you don't know how to do it yourself
since shop rates are different in a local region
expect to start @ ~$100 and go from there for a typical "tune up"
basically changing spark plugs & checking the cap/rotor/wires/ timing/ etc...
Old 04-27-2009, 07:34 PM
big tex84's Avatar
big tex84 big tex84 is offline
what codes are being thrown? map sensor could also be causing fluctuating idle, also if it is flooding out check your injectors, i had one on my d15 that was stuck open and it would flood out and die, just some suggestions, good luck
Finally getting my swap done, Thought I would be relieved and satisfied, now I just wanna spend money on other car parts, WHERE DOES THE MADNESS END!!!!
