Old 03-29-2003, 04:34 PM
logixSI logixSI is offline
Question Removing rear reflector
Not sure if that’s what it’s called, but I’m trying to remove it to paint it. Problem is, there is a latch holding it on. It looks like it would slide right off, but its not happening. Any tips on removal? Should I just snap it? If I do will there be much (if any) rattling when I put it back on?
Old 03-29-2003, 04:49 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I couldnt get mine off, so I painted it right on the car
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-29-2003, 05:08 PM
Looks good. Didn’t you post a how-to on how you did it? I can’t seem to find it. Also I'm looking to paint it white. Any idea on what kind of paint I should use for it?
Old 03-29-2003, 05:55 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
DO NOT PULL HARD ON THE PIECE, YOU WILL SNAP IT! I HAVE DONE IT. THE TAB IN THE CENTER THAT IS HOLDING IT IN IS A FUCKING BITCH, AND I HAVE FOUND THE BEST WAY TO DO IT IS TO GET A GOOD SET OF NEEDLENOSE PLYERS AND SQUEEZE THE SIDES OF IT. ALSO TRY TURNING THE TAB 90 DEGREES.
I REPEAT DO NOT PULL HARD, YOU WILL SNAP IT RIGHT DOWN THE MIDDLE!!!!!!
i snapped mine. $100 bucks or something for a new OEM one from Majestic Honda. I pulled mine off cuz the damn seal was leaking. Oh well, new gaskets came with the new one so that problem is fixed. now it leaks somewhere around where the bumper is attached below the trunk line. water pools at the bottom of my spare tire well on top of my dynamat.
Old 03-29-2003, 05:57 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
i know on my rex, there is a few nuts holding it on behind those removable plastic covers, after that i just tilt it upwards and it comes right off, but it may be different for your car.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-29-2003, 06:22 PM
Melt's Avatar
Lol, mine started to crack so I quit while I was ahead
AF Bay Area Crew
Old 03-29-2003, 06:44 PM
Melt's Avatar
Here's a how to
As far as paint I have no idea ... but lemme reccomend picking up a centerpiece from an STD hatch to paint, and selling your SI centerpiece (assuming you can get it off), because you will make some money on the deal, there are a lot of people who want the reflective red.
Here is a pic of the STD center in case you dont know what to look for.
AF Bay Area Crew
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Take off the plastic panel on the hatch, there is a big hole on the back, stick your hand with some pilars in it and undo it from the back. Not that hard. I did it in the pitch dark at night.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
