Old 04-18-2009, 08:08 PM
daufoi daufoi is offline
Cam sensor troubles.
how can i get the pdf of this procedure?
Old 04-19-2009, 10:03 AM
Fordhcw Fordhcw is offline
Re: 1997 Tauras 3.0 Camshaft Position Sensor
I have a 1998 Ford Taurus with the 3.0L 12 valve Vulcan engine and automatic transmission, which intermittently gets the error code for the camshaft position sensor only in very cold winter weather. Since it never got worse, I never replaced the sensor. The camshaft position sensor is the type with two terminal pins. Has anyone else had this error code only in very cold winter weather?
Old 04-19-2009, 05:32 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Which code are you getting? It should be in the form P0123.
-Rod
Old 04-19-2009, 05:53 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Cam sensor troubles.
I moved this from the post dated October 2006. Started another thread with it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 04-22-2009, 12:27 AM
ifixcrap01 ifixcrap01 is offline
so just replaced a block in a 97 turus finally got it running. thr cps is not in right how to you get it lined with top dead center
Old 04-22-2009, 06:50 AM
shorod's Avatar
SHO No Mo
There have been many threads related to the CPS and whether or not the special alignment tool is necessary. I don't want to make another thread on the topic here. Please use the "Search this forum" tool from the Taurus forum main page.
-Rod
Old 04-24-2009, 01:15 PM
Willyum Willyum is offline
Enter "30-S2600" in the Google search window and you'll find out more than you need to know about CPS.
