Old 04-19-2009, 03:15 PM
americanbulldog americanbulldog is offline
need help with tranny fluid leak
a few days ago i noticed trans fluid leaking.i have not tried to find the leak yet but i looked under the truck.and if im in the front of the truck and look upder it seems to be like 6" before the oil pan but up in the bay more.what is there that could be causing this and are trans fluid leaks usually costly?
Old 04-20-2009, 07:05 AM
534BC 534BC is offline
Re: need help with tranny fluid leak
Are there 2 lines running up to the radiator for cooling? That can be it.
Old 05-26-2009, 10:32 PM
i took the metal skid plate off that blocks me from seeing under the front on the jimmy,and when i did i noticed 2 thin metal lines that looked rusted as hell.they seemed to lead up to the radiator somewhere.and seemed to be coming from around the trans some where.so could that be the trans cooler lines? and that could be the problem if they are.
Old 05-26-2009, 10:43 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Yes and yes.
Such lines often will rust out over time and leak. New lines can be bought in various lengths, already flared and with the correct fittings. The lines can carefully be bent to to match the old lines, then the fittings are attached in place of the old ones.
Old 06-04-2009, 09:18 PM
do they sell lines that are pre bent with the correct fittings already on them.so i don't need to bend them or get fittings.
where would they sell them.
thanks
Old 06-04-2009, 09:29 PM
Best chance for that is the dealership.
