Old 04-19-2009, 08:25 AM
Wootmaniac Wootmaniac is offline
Front/Rear speaker feed question
I have two older stereo am/fm cassette radios I used in cars I had and they are almost new. I thought about hooking one up for use in the garage and wonder if I only use the front speaker wires.....what should you do with the rear wires as they'll be trying to run a signal to rear speakers which I won't be using.
Tie together?
Run through some type resistor? If so what value?
Thanks in advance...
Old 04-19-2009, 04:12 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Front/Rear speaker feed question
cut them until there is no exposed copper, then tape them up. If there is no load it just won't be pulling exta power from the headunits amp.
Old 04-19-2009, 06:19 PM
quick69gto quick69gto is offline
Don't tie them together. The head units amp won't take that for very long.
Cut them off/ tape them up as suggested.
Old 04-19-2009, 09:46 PM
AWP9521 AWP9521 is offline
Agree with the cutting and taping of the unused wires, I prefer using that heat shrink tubing with the adhesive lining, once that cools it's pretty much permanent.
I also recommend setting the fader control to the front position, that will cut all audio signals to the rear channel amp inputs, making the rear amps totally idle at any volume level.
Other than acting as an extra heat sink for the front channels
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
