Old 04-19-2009, 02:22 AM
painter_boy painter_boy is offline
2000 jimmy cruise control fuse
my cruise control fuse keeps blowing. this also causes my gas gauge, temperature gauge, and my odometer not to work. i talked to a mechanic and he said to get a new gauge cluster. i bought one and put it in. it worked for a few minutes and the the fuse blew again. Anybody have any suggestions before i start going broke from buying new parts that i dony need. thanks
Old 04-19-2009, 08:40 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 jimmy cruise control fuse
Cruise fuse 3 in IP panel?
Always use good Buse fuses.
No wallmart Chiana specials.
Ask your mechanic if he wants to eat a new insturment panel?
That fuse feeds the insturment cluster and Body module and lumbar seat switch and muti function switch and cruise module.
Does the fuse blow engine running or just key on?
In case of short /blowing fuse you will have to start unpluging everything that is on that fuse circuit untill you find the short.
A good wiring diagram will help you find the stuff and wiring.
Also a good circuit breaker fuse the same amo will save on fuses.
Good Luck and let us know how it goes.
MT
Old 04-19-2009, 11:24 AM
i unplugged everything one at a time and it does not blow when i unplug the cluster. the fuse blows with key on but not always right away.
Old 04-19-2009, 11:38 AM
MT-2500's Avatar
AF - Advisor
Better check the cluster or cluster wiring.
Good Luck
MT
Old 04-19-2009, 11:46 AM
MT-2500's Avatar
AF - Advisor
Does it do same thing old or new cluster?
Possiable something wired to the cluster has a short.
Get a good wiring diagram and check everything wired to cluster for short.
Some electrical places have a short finder deal.
May help you pinpoint short.
Let us know how it goes.
Good Luck
MT
Old 04-19-2009, 03:21 PM
b1lk1 b1lk1 is offline
PS: Get a new mechanic. Anyone that calls themselves a mechanic and charges people for their advice/labor should not suggest throwing parts at it in the hopes that it will fix it.
Old 04-19-2009, 04:50 PM
it blows with new and old cluster. i am going to look at it tonight and see if i can find anything. thanks for the suggestions so far.
Old 04-19-2009, 05:20 PM
MT-2500's Avatar
AF - Advisor
You could have a bad new cluster or one of the wires to the cluster is shorted.
Check plugin on cluster real close.
And try to pinout cluster wiring outside of ground for short.
Has any rewiring or repair been done it when cluster fuse started blowing?
MT
