Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 04-18-2009, 06:41 PM
Cadillac Killuh Cadillac Killuh is offline
1993 Caddy Seville
4.9 V8. My caddy has idling and running issues. Car RPMs race up and down when idling. Recently car has shut off while idling in park and while driving. Replaced Idle Speed Control Actuator. The arm still moves in and out of the actuator, moving the throttle body up and down.
Daily driver and need help!
Old 04-18-2009, 07:16 PM
maxwedge maxwedge is offline
A990 racer
Re: 1993 Caddy Seville
Welcome to AF, any check engine lite on, has a full scan been done? The usual suspects here are a vacuum leak, bad tps, carboned up throttle body, sticking egr.
Old 04-18-2009, 07:45 PM
How do i go about this process without blindly replacing parts. Would these potential issues show up on a scan?
New Idle speed Control Actuator still malfunctions, after new one was installed.
Old 04-19-2009, 08:26 AM
A990 racer
The t' body should be cleaned, the egr removed and cleaned, then leave it disconnected for test purposes, a scan should be done for tps operation and any vacuum leak source should be checked.
Old 04-20-2009, 08:58 AM
DFBonnett DFBonnett is offline
Did you adjust the ISC motor after installing it? Also, as noted, a common cause of the idling problem you experience is a dirty throttle body and plates.
Old 04-30-2009, 02:03 PM
Sorry for the delayed reply. I cleaned out the throttle body and plates and car runs much smoother! My car still idles too high, at startup it races to 2000 RPMS. I did adjust the Idle Speed Control Actuator. I am wondering the proper way to adjust the idle.
Old 05-01-2009, 07:26 AM
Try this.....
Idle Learn Procedure
• The TP sensor/IDLE LEARN should be preformed when-
• TP is replaced
• throttle body replaced
• PCM replaced
• battery disconnected or replaced
• PCM code 52
• IAC adjusted
• TP sensor adjustment has been preformed
min idle speed adjust procedure has been preformed
IDLE LEARN PROCEDURE ***4.9L***
1-outside temp is 50 degrees or greater
2-start engine and idle 13 min
3-at end of 13 min- enter diagnostics (engine running)
4-turn engine off
5-wait min of 20 sec
6-turn ign on (engine off)
7-enter diagnostics
8-turn ign off
9-wait min of 20 seconds
10-turn ign on (engine off)
11-enter diagnostics
12-turn ign off
13-wait min of 20 seconds
14-start engine
15- appy brakes and shift into 'drive'
16- turn the ccp 'off' and allow engine yo idle 1 minute
17- turn the ccp to 'auto' make sure AC comp engages- idle for 1
minute
18- put car in park and turn ign off
Old 05-01-2009, 02:39 PM
This is how you adjust the idle? What do you mean by enter diagnostics? What is the CCP? And i do not have an AC Compressor, i have a dummy pulley.
