Old 04-18-2009, 10:15 AM
bamendaboy bamendaboy is offline
3.3 tensioner replacement
Hey all, can someone give me a step by step instructions on how to replace the tensioner? If possible, picture diagrams would be appreciated. My belt keeps slipping off. I have a 93 Caravan. Thank you in advance.
Manual 97 Eclipse
GS Non Turbo
4 Cylinder
2.0 L
150k
Old 04-18-2009, 02:41 PM
Oldsmobile Doctor Oldsmobile Doctor is offline
Re: 3.3 tensioner replacement
Getting ready to do one tomorrow (Sunday 4-19-09) I will let you know.
Old 04-18-2009, 06:31 PM
Bear Bear is offline
Not fun, the problem is that the retaining bolt is behind the tensioner and you are almost working blind. Try going to AUTOZONE website, registering and then looking at repair info for your car. I just did mine on a '96 3.3 liter and was able to use a ratcheting box end wrench on the nut, but it was not easy and I have the battle scars to prove it.
Old 04-20-2009, 08:26 AM
I used a 15mm swivel on a 10 in extension. Not too bad but I also had to replace the power steering pulley and that was.
Old 04-20-2009, 09:55 AM
I started mine on Saturday but i am gonna finish it today. I had to move my Alternator out of the way so i can gain some leverage to swing the wrench/ratchet.
I will let you guys know how it went. My question is, is this the reason my serpenting belt keeps slipping off?
Manual 97 Eclipse
GS Non Turbo
4 Cylinder
2.0 L
150k
Old 04-20-2009, 10:30 AM
Easier from the bottom.
Old 04-20-2009, 10:51 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
If you look at the pulley on the tensioner and it looks like the belt has been riding more to the outside and there is about 3/16" of rust on the inner part of the pulley where the belt used to ride than yes, replacing the tensioner is a good start.
Agreed, it is a lot easier to do from the bottom!
Old 04-20-2009, 06:57 PM
Mrbizness1 Mrbizness1 is offline
I would put a wrench on the tensioner and pull on it. If you get a lot of resistance then the tensionor is good. If the belt is off it is a good time to feel the other pulleys for wear and run out. I have been lucky, 139k on a 98 3.3 with the original tensionor. When I change the oil I spray lithium grease behind it. Dorman sells a item to keep the belt from slipping off. I have changed 2 pulleys.
Its part # 82570
https://www.dormanproducts.com/cgi-b...p1&vtime=71714
Old 05-22-2009, 10:58 PM
93plygravoyse 93plygravoyse is offline
I have a 93 plymouth grand voyger se 3.3 I just bought a duralast tensioner assembly it looks like it just threads on instead of having a bolt to undo has anyone done this on my specific model? I looked on autozone for a guide there was no specific info and I have searched this forum with no luck exept this thread..I did not want to start a new thread about this that is why i am asking here here are pics of the new tensioner
Old 05-23-2009, 10:34 AM
From under the van just over the power steering pump is the nut for the idler it is 15mm. I used a swivel socket on a extension I had a harder time getting the belt back on. The new tensioner had a lot more spring to it.
Old 02-25-2010, 11:09 AM
bjaymo3 bjaymo3 is offline
Send a message via AIM to bjaymo3
The nut is on the other side of where the bolt mounts. The bolt on the tensioner goes through a brace and the nut is on the other side.
2002 Grand Prix GT 3.8 V6
1998 Dodge Grand Caravan 3.3 V6
1998 Chevy Blazer 4wd 4.3 V6
