Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 04-18-2009, 07:16 AM
seanbreeze seanbreeze is offline
89 Firebird wil not run.
I have an 89 firebird that will not stay running. It will start and idle but when you put any throttle you give it any gas it stalls. The pump,filter,regulator,tps have all been replaced. All injectors are hot and have a good flash. The fule pressure is @ 45 psi when idling and holds when not running. I have tested all I can think of. Anyone have any advice where to look next? The check engine light is not on. The car remains running for as long as you do not give it any gas. HEEEEEEEEEEEEEEEELP please!
Old 04-20-2009, 01:52 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 89 Firebird wil not run.
The problem must be in your ignition system then.
Old 04-20-2009, 02:24 PM
CoolasIce CoolasIce is offline
Is it that simple?
What about the throttle pos. sensor, or map or maf sensor?
Old 04-21-2009, 07:06 AM
I have also noticed that when I reattach the snorkel from the air cleaner it stalls as well. Could this be the mass air flow? If not where should I start in the ignition system? It has that factory security chip in the key. Thanks
Sean
Old 04-22-2009, 12:42 AM
Morley Morley is offline
Sean
I'm going to guess that it is a TPI engine. try disconnecting the MAF sensor, then start the car and see how it does.
You say you replaced the TPS.. Did you set it properly?
Old 04-22-2009, 10:43 AM
No change when I unhooked the MAF sensor. As far as the TPR being reset I am not sure. All of that was done before it was brought to me but it is only 3 weeks old. If I unhook the TPS no change as well but if I move the arm on the side of it then it syalls out as well!
Thanks for helping me with this monster!
Sean
Old 04-23-2009, 12:11 AM
Sean
If you move the arm on the TPS without moving the thrittle it will stall. The ECM is addng fuel because it thinks the throttle is opening and it isn't. Basically it floods the engine.
To set the TPS tou need a digital volt meter hooked to pins B & C od the connector with it hooked to the TPS. Then turn the key on and set the meter to DC volts. It should read .54V +/- .017v. To adjust it loosen the screws on it and move it to get the proper reading. then tighten them back down (carefully, they are aluminum screws) while watching the voltage.
If that does nothing for you, you could try a through throttlebody cleaning, including the IAC and its passages.
Old 04-23-2009, 09:36 AM
wrightz28's Avatar
Sean
No no, by ignition system, I mean the engine's ignition system (spark).
Since you gave the entire fuel system an overhaul, when is the last time the plugs, wires and cap & rotor were replaced?
Old 04-24-2009, 06:57 AM
The tune up was done just after he bought the car about 3 weeks ago and I did that myself. The car ran great after that and the problem I am having happened all of the sudden.
Old 04-24-2009, 06:59 AM
Thanks will give this a try....If I can find the diagram for the pins. If not I think a big hammer might help me fix her up ~Ώτ
Old 04-24-2009, 10:17 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
when it actually is idling, does it idle nice and smooth? or is it rough and possibly running rich?
Old 04-25-2009, 06:28 AM
purrrrrs like a kitten till you hit the gas
Old 04-25-2009, 12:27 PM
Should be the bottom and middle pins.
Old 04-27-2009, 02:54 AM
91 bird 91 bird is offline
Red face Re: 89 Firebird wil not run.
i had a problem like this, it turned out that the PCV system was cloged. prior owner dint know you had to do oil changes from time to time.
